MURRAY FEISS P1391ORB 1 2 IN. - LED GLOBE PENDANT OIL RUBBED BRONZE
The globe pendants™ LEDs shine inward from half the arms while the inlay details adorn the opposite arms to catch the light. The sconce embedded LEDs throw light back toward the wall to create a warm glow on the back plate metal insert which is stamped with a subtle linen pattern and finished in a contrasting tone to the fixture's overall finish to complete the modern look. The pendants of vast scale and the ADA compliant sconces are all ideal for commercial applications or more dramatic residential installations.
Features- Featured in the decorative Khloe collection.
- CETL listed for dry locations.
- Supplied with 15 ft. of wire.
- A great choice for your do-it-yourself project.
- Decorative oil rubbed bronze finish to accent and brighten your room.
- The preferred brand choice of builders and electricians.
- No. of Rods: 4.
- Rod Length(s): 12.00.
- Color Temperature: 2700.
- CRI: 80.
- Lumens: 475.
- Hour Rated: 64000.
Specifications- Height - 13.50 in.
- Width/Diameter - 12.00 in.
- Wire Length - 180.00 in.
- No of Bulbs - 2.
- Standard Wattage - 4.25w.
- Bulb Type - LED.
- Voltage Rating - 120V.
- Material - Steel/Aluminum.
Price: 798.20
